Old 08-28-2024, 09:07 AM   #21
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Default Re: Hoosier C30 Compound
Anyone noticed a difference in radial vs bias ply for et predictions? Just wondering out loud if the softer sidewalls could introduce more variability. Probably overthinking, but not afraid to ask the 'dumb' questions either.
Andy Friar
Andy Friar is offline   Reply With Quote
Old 08-28-2024, 12:44 PM   #22
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 228 Times in 98 Posts
I've never seen a car get less consistent when put on radials, unless the car was just blowing the tires off on the starting line.
Now, I've never seen a car that just couldn't handle radials either, but I've had to work on my own car a couple times after making a somewhat significant power increase.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 03-17-2025, 10:13 PM   #23
1700camaro
Liked 228 Times in 117 Posts
Originally Posted by 1700camaro View Post
Finally found a product bulletin on this tire. I still only have 9 passes on these tires. I'm pretty sure I can win on them.
I hope to get more testing/racing on them this fall.
https://www.hoosiertire.com/images/c...30%20(002).pdf
I installed the Hoosier FSS C30 compound slicks today for testing/racing this coming weekend. Hope to finally get some good data on the tires.
I weighed the tire & rim configuration between my M/T PBRs/double bead lock rims to the FSS tires/Weld no beadlock rims. There's a total difference of 24 lbs. weight savings.
Hopefully they work good enough to use for the Spring Fling Million in Apr. if I decide to enter.
1700/STY/781L
You earned/deserve the vast majority of unfriendly & different names earned by you due to your BS. Embrace them names, they're the Real Truth.
1700camaro is offline   Reply With Quote
Old 03-17-2025, 10:41 PM   #24
MRE 7171
Liked 127 Times in 26 Posts
If the Hoosier 18213 is 94" circ. and this tire is for factory stock, what rear gear do they run and how much horsepower are those cars
MRE 7171 is offline   Reply With Quote
Old 03-18-2025, 12:57 AM   #25
1700camaro
I don't know the power they make, but it's more than mine. This is just a small tire bracket car set-up to run mid 8s. I'm only legal to run 8.50 & the biggest problem is I'm not legal to run 150 mph +, yet.
Below is/was my gearing. I have no idea on the HP, it hasn't been on the dyno.
1700/STY/781L
While the updates to the Camaro wasn't meant to make it quicker or faster; it did happen. I got out of the throttle around 4.5 sec. into the run & ran a 5.6x @ 123+ mph to the 1/8th. We part throttled to the 1/4 mile & went 8.8x @ 143 mph. That's .1 quicker than our best at both distances & that was getting out of the throttle/part throttle.
I changed the rear gear from a 3.89 ratio to a 3.55 to knock some rpm out of the finish line. I guess it liked the change. The converter flash stall raised from a little over 5,500 rpm to a little over 5,800. The shift drop went from 1,000 rpm to 600 rpm drop. Pretty much what Kevin @ Hughes Transmission predicted.
Old 03-18-2025, 10:06 AM   #26
james schaechter
Liked 1,443 Times in 302 Posts
The only 9 inch PBR I have seen is only 28? tall and 88 rollout. What size were your PBR?s?
I ran some 13.5 x 31 PBRs for years for an everyday slick on my Cavalier LT1 stick car. When I took them off last fall at Vegas, they had 193 runs on them and looked great! The date code was from 2017 and I bought them in 2018. I gave them to a local bracket guy?
They were 9 lbs each heavier than a standard radial but you cannot wear them out!
1700/STY/781L
James Schaechter 3163 STK
Old 03-18-2025, 05:30 PM   #27
1700camaro
Our primary tire is a 29.5 x 10.5 PBR, it has a 94" RO & the width is only 10". I get an easy 150 runs out of them & they're still working great when I change them out.
When I first started running radials many...many moons ago. I started with a Hoosier 30 x 9 C06 lightweight & got an easy 150 runs out of them. I've ran all the different model 9" Hoosiers. They're great tires, but the PBRs edge them out slightly for bracket racing.
1700/STY/781L
Old 03-24-2025, 11:53 PM   #28
1700camaro
We put 9 runs on the tires this past weekend. They worked pretty good & only had one pass I didn't like. It wasn't the tires fault; there was drippings on the inside left groove. I straddled them the best I could but don't know where the drippings were down track. My 60' was a little off & the tires were searching for traction down track.
Performance wise, the total rotation weight savings made little to no difference in ET & I wasn't looking for one.
I decided to enter the Spring Fling Million & parking is one week from today. I'm going to double enter in Pro & Super Pro for the (3) 30K races & single enter in the Wanna-Be Million.
1700/STY/781L
Old 03-25-2025, 03:01 PM   #29
1700camaro
1700/STY/781L
Correction: I can only single enter in the 30K races. I can double in 2 different categories for the Wanna-Be Million.
