Old 03-07-2025, 04:53 PM   #11
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: How did a milidon 30401 pan become a stock replacement?
any oil pan can be extra deep... if you drain enough oil out LOL
Old 03-07-2025, 06:48 PM   #12
SSDiv6
The Milodon 30401 is a copy of the 6 qt Chevy Corvette SBC oil pan. 5 in the pan and 1 in the filter.
Moroso has an equivalent to the pan under P/N 20180 and it is also NHRA approved.
Both pans have been approved as a replacement to the OEM 5 qt oil pan.
Should NHRA ban the use of oil accumulators too?
Old 03-07-2025, 09:40 PM   #13
Lyn Smith
Liked 1,002 Times in 203 Posts
Any companies pay oil pan contingency?
Old 03-08-2025, 08:12 AM   #14
TOSTO RACING
TOSTO RACING's Avatar
Liked 665 Times in 187 Posts
After you guys figure out the oil pan you may want to look into how 396/375 Camaros (just one popular example we all know there’s many more )can run 9.50’s at 3600 pounds stock ! Lol I think the least of anyones worries are an oil pan at this point . This class is out of control lol ! No tech, no tear down , but get that fuel checked after a qualifying run lmao!!!!!!
5664 GHI/SA
1985 CAMARO RED H/SA --- FOR SALE
1985 CAMARO BLUE I/SA --- SALE PENDING ON BLUE CAMARO!
TOSTO RACING is offline   Reply With Quote
Old 03-08-2025, 08:41 AM   #15
Liked 11,029 Times in 2,266 Posts
Since the oil pans are allowed to be bigger two or three quarts, it would probably be ok to increase runner volume 25cc or valve size .040 on diameter, or make the head 10cc smaller.
Old 03-08-2025, 04:47 PM   #16
Liked 1,951 Times in 439 Posts
Hyperbole much???
No insult intended, but, seriously, with all of the utterly egregious stuff in Stock, you REALLY want to worry about THAT oil pan?
Old 03-08-2025, 08:05 PM   #17
Brian Oakes
Liked 439 Times in 116 Posts
Larry
You must be Wineing to get HP off your combo, hit speed dial for Pat's Number
Brian Oakes is offline   Reply With Quote
Old 03-08-2025, 11:15 PM   #18
SSDiv6
The truth is that having a bigger pan does not mean you will be gaining additional power. You make more power by controlling the movement of the oil inside the pan and diminishing windage.
