Liked 708 Times in 285 Posts
Liked 711 Times in 205 Posts
Be careful it will eat away concrete. It will help with the rust (not oil) have plenty of water available to rinse off and follow trail as it will leave a stain of the water trail on your concrete if not scrubbed off well.
Mike 7570 A/SA |
Liked 759 Times in 379 Posts
Mike, KNOWS. I wouldn't use muriatic acid if you've never worked with it before, surface degradation and cracks are a common result. Use Sure Kleen instead.
Liked 354 Times in 120 Posts
Flame away, If out side use small amount of reg gas scrub with a broom cover with floor dry sweep it up, it will be spotless. Just did it today on my sons driveway from a tranny line leak. Tom
Tom Meyer 5240 SS Stock ??? Last edited by Tom Meyer; 02-28-2025 at 10:53 PM. |
Liked 2,768 Times in 980 Posts
I used drain cleaner and it worked well. About 90% successful.
Hardware guy said same thing and while a nice driveway when washing off I have about 3 puddle areas and the along driveway is slightly higher. So wouldn't be able to remove all acid. I had purple power it really help alot.
Ed, sure clean you feel alot stronger then purple power? If so then I'll try it.
Yes, we use it all the time to clean concrete and brick.
Liked 150 Times in 41 Posts
Oil eater. You buy it from amazon or Home Depot. Or try ZEP A-1.
