Old 02-09-2025, 05:08 PM   #1
67 Post GS
67 Post GS's Avatar
Liked 48 Times in 10 Posts
Default Re: 2002 Buick 3800
I would go-ahead and replace the plastic upper intake all together. They will warp over time, and then you put a fresh gasket underneath and it will still leak. Dorman makes a replacement.
67 Post GS is offline   Reply With Quote
Old 02-15-2025, 11:24 PM   #2
4speedracer
Liked 10 Times in 6 Posts
The Dorman intake used to come with a different internal EGR tube to get the heat away from the intake. OE configuration would damage the intake, sometimes leak internal and hydraulic the engine. Would suggest doing the lower intake at the same time, the general used plastic lower intake gaskets also replacements can be gotten in metal with rubber inserts.
4speedracer is offline   Reply With Quote
