Old 01-29-2025, 05:50 PM   #1
1legjerry
Liked 72 Times in 15 Posts
Default Re: No oil to rockers?
If all you did was change cam and lifters(nothing else) then I would say you got the wrong lifters. What year 283?
Have some work the drill and then turn the crank by hand at the same time.
1legjerry is offline   Reply With Quote
Old 01-29-2025, 06:00 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
1legjerry…KNOWS
Old 01-29-2025, 07:07 PM   #3
Kenney Kelley
Liked 72 Times in 36 Posts
Does your cam have the notch at the rear journal or does all Chevrolet cams have that? Did you by any chance put the 6 plugs in the block to far? When you primed the block did you remove the 1/8" pipe plug in front of the block to see if you are getting oil up front, if so it might be what the other Gentlemen have said about the lifters or have you run a wire down through the push rods? I know this is basic knowledge and I know you probably have built alot of Chevy Motors in your life time but you were asking for suggestions.
Kenney Kelley is offline   Reply With Quote
Old 01-29-2025, 08:16 PM   #4
Barry Polley
Guest
Posts: n/a
Remove the intake, prime it, does the oil exit bottom of the lifter heavily? If so the lifter is wrong .
Old 01-30-2025, 08:45 AM   #5
curtis reed
Liked 126 Times in 60 Posts
This may sound crazy but I have seen it. Did you look at the lifters to make sure they all have the oil hole drilled in the band?
curtis reed is offline   Reply With Quote
Old 01-30-2025, 09:11 AM   #6
G money
Liked 13 Times in 13 Posts
check the oil hole in the lifter and see if it meets the oil galley, if it doesn't then mill a .003 groove from oil radius on lifter to oil hole on the lifter. I had to due that on my son's super stock motor, they where not cheap lifter's .
Gary Walters
G money is offline   Reply With Quote
Old 01-30-2025, 12:24 PM   #7
Barry Polley
Guest
Posts: n/a
We?ve had to take a dremel and very slightly grove down ( tiny groove) from the oil hole to the recess. Seen this about a dozen times.
