Old 01-06-2025, 10:55 AM   #111
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Default Re: What has changed in Stock Eliminator since 2015?
Originally Posted by Dean Feiock View Post
Just curious what significant changes have taken place since 2015?
Life had a different direction for me for the last 10 years. But now I'm at a spot that I'm considering racing again. My thoughts are either going back racing in Stock OR make it a Drag and Drive car. The car has been sitting untouched for years. Obviously, everything that is there will need to be freshened or replaced.
Just some of the questions I have:
1) What major rules have changed over the last 10 years?
2) What can or what should be updated to be competitive based on rule changes over the last 10 years?
3) Are things like digital ignitions & data acquisition a must even on an old school carbureted stocker?
Hydraulic cams can now be solid lifter, roller rocker arms as long as they maintain stock geometry and style mounting. Data acquisition is a good tool but many do not use it. Replacement heads are allowed in some combos. Auto 1-2 is allowed as long as it?s an act of the transmission not an external device or elctric. Larger cam diameter is tolerated.
Pretty much it
Old 01-14-2025, 10:27 PM   #112
Jack McCarthy
Liked 477 Times in 117 Posts
Red face Re: What has changed in Stock Eliminator since 2015?
ill make this quick
1st there is an automatic horsepower factoring system also know as ahfs automatic help for slugs > penalty for being good at cheating the rules
2nd there is no longer any formal tech you enter online and solemnly swear its a 305 not a 350
3rd as you see there is plenty of wanna be has been keyboard jockeys on here
4th be prepared for some 160mph action in the traps nhra chose not to give the super cars thier own class
5th a second under is a pretty decent run (itll get you a review by ahfs)
6th we always go out at an obscene time like 7am and late like 8pm good luck dialing
7th they gave us unlimited valve springs and rockers sooooo cams / lifters cost more than SS stuff
8th if you wanna run national events pony up $250 x 8 divisionals
glad to have you back
captain
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is online now   Reply With Quote
Old 01-16-2025, 04:50 PM   #113
Rod Greene
Liked 242 Times in 81 Posts
So how do you set this up to ignore somebody?
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 01-16-2025, 07:10 PM   #114
J.R. Haddad
Liked 1,470 Times in 308 Posts
Cap't. Jack. you've only covered the good things about Stock. What about all the other stuff??
J.R.
J.R. Haddad is offline   Reply With Quote
