Old 10-19-2024, 12:59 PM   #20
jmantle
Liked 172 Times in 81 Posts
Default Re: Yet another metric 200 question
Originally Posted by mike britt View Post
So I got the bushing out of the front pump and studied it. It has a lot of wear on one side and has never touched the converter on the other side. Looks like the ultra bell housing is not lined up and causing misalignment between the crankshaft and the transmission input shaft.
What you're seeing on the bushing wear isn't necessarily an ultrabell problem. The discharge side of the pump forces the gear and converter neck to one side from the hydraulic pressure so wear on one side is normal.. That said, hanging the bell housing on 6 8mm bolts doesn't guarantee good alignment.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
