Old 10-06-2024, 05:46 PM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Rear gear question
And more tire.
As I stated in post #5
Old 10-06-2024, 06:30 PM   #2
CMcAllister
Liked 920 Times in 259 Posts
My handy dream wheel says 133 is 10 flat horse power, 600 - 620 HP or so.
1.45 60' isn't hateful. Probably has mid 1.30 in it anyhow. A 3 speed, with the extra SLR should make it 60' a little better. A lightweight 3 speed would be even better.
Depends on your goals. More rear gear, as was said, will help. Agree with a 5800 converter. Beyond that, if it's consistency on marginal tracks, you're probably best with that low gear. Want to go fast, need the low gear a 3 speed would offer. And more tire.
Old 10-06-2024, 07:16 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
Need a neutral or negative converter to get it to pull off line & the gear change.
5800 stall OK, but there is more to the converter than stall speed.
I agree with tire and rear gear change.
1.96 low might wake it up too, but shift it at higher RPM with a lower low gear PG.
You are carrying quite a lot of weight for a 7.38 starting line ratio...2.52 low gear 3 speed puts the SLR at around 10.33. With the right 3 speed converter it would pick up a bunch. Probably on the + side of .15..
Adger Smith (Former SS)
Old 10-06-2024, 07:31 PM   #4
Adger Smith
oops!
Old 10-07-2024, 11:45 AM   #5
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 226 Times in 97 Posts
I have to think the converter is real tight.
My Nova is 3600#, 1.80 glide, 4.10 gear, 28" tire and has 660 HP. I can't go 133; 128 is about the best it'll do but it's usually a 1.40 60'.
So, same running gear setup but heavier and less power.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 10-07-2024, 12:25 PM   #6
1320racer
1320racer's Avatar
or heads are too big
Old 10-07-2024, 07:29 PM   #7
CMcAllister
or cam
Old 10-07-2024, 07:45 PM   #8
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
3400# car, 28" tire, 739 HP, Auto trans
I would want to see somewhere around an 11.5 SLR
NOTE this is ONLY a recommendation for what might be a good STARTING POINT
Stan
Old 10-07-2024, 09:57 PM   #9
L.Fite
Liked 497 Times in 243 Posts
5.14 and a 3 speed might get him there...
L.Fite is offline   Reply With Quote
