Old 09-20-2024, 09:19 PM   #9
Woodfin
Liked 288 Times in 109 Posts
Default Re: Suspesion setup with radial slicks "help"
In my experience, and as Ed said, because of the front weight, OE-type springs would be better. Landrum has a wide selection of drag-front sprigs to fit the factory location. The front needs as much travel as possible, and the static front height should be slightly lower than stock. One no-cost mod is to relocate the front upper ball joints to a new location, on the bottom of the control arm, not the top. Doing this will at 1/2" + to the front travel. Also, the front system should be free and move smoothly.
