Old 09-18-2024, 10:11 AM   #1
goinbroke2
Liked 404 Times in 158 Posts
Default C4 help needed
Have a 1975 c4 with a broader performance reverse pattern valve body. Followed directions exactly (so I thought) I have p,r,n,locked, 2nd,3rd. Pulled the valve body and double checked all my springs/balls/grinding and everything looks like the diagram. Put it back in, the same. Pulled the valve body and put a stock one in and it works normal. Pulled the stock one and went through the reverse pattern one again, triple checking.
It appears it's in 1st and rev (tranny brake) but I don't have a tranny brake and didn't grind the hole to install one, but, it's acting like one.
This morning I went back out and installed the reverse pattern one and fired it up....I now have P,nothing,neutral,1st,2nd,3rd.
So now I have 1st but no reverse. I'm going to run it for a bit and make sure the oil level is good but if it runs 1,2,3...
Anything obvious I'm missing here? I'm not doing something right, I just don't know what. Had rev/1st which locked it, now I have no reverse and I have 1st...I don't know the circuits enough to know what that means.
Help.
Someone (Gary Lucier?) posted some links to a c4 build but of course I can't find them...
Jim Miller
103 U/SA
Old 09-18-2024, 11:46 AM   #2
Mike Gray
Mike Gray's Avatar
Liked 699 Times in 202 Posts
Default Re: C4 help needed
Check out Class Racer Builds pg2 C4 build by “West Coast”
Mike 7570 A/SA
Old 09-18-2024, 11:56 AM   #3
goinbroke2
Originally Posted by Mike Gray View Post
Check out Class Racer Builds pg2 C4 build by ?West Coast?
Thank you! (I knew somebody knew where it was, lol)
Jim Miller
103 U/SA
Old 09-18-2024, 03:54 PM   #4
jmantle
Liked 172 Times in 81 Posts
Help.
If it's locking up in the first gear position but the rest of the gears are normal, sounds like the high gear clutch is applying, as it would if you had a transbrake applied. Sounds like something is misassembled, I'd start by checking out the 2-3 shift valve.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 09-19-2024, 10:33 AM   #5
fordteacherguy
Liked 160 Times in 51 Posts
Jay has a video addressing installing his manual VB kit. His products are top notch..so double check installation procedures.
James Boyce (West Coast) also has has a complete c4 build under Class Racer Builds Section..its at the top of page 2... easy to find...good luck!
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 09-19-2024, 12:35 PM   #6
What do you need a reverse pattern , Tbrake valve body for , if I might ask.
The trans seems the work, so why not just buy a TransGo manual shift for a hundred buck and be done with it? Sounds like you're a glutton for punishment LOL
Old 09-19-2024, 04:03 PM   #7
Billy Nees
Ummm, just asking for a friend, wasn't there an "issue" with imitation Made-in-China Broader Performance valve bodies recently?
Billy Nees 1188 STK, SS
Old 09-19-2024, 04:56 PM   #8
pmrphil
Liked 348 Times in 152 Posts
Only the junk sold by Summit and others. Jay does not sell through any of the mail order houses, only direct.
Phil Molski
PMR Performance
S/C 1623
Old 09-19-2024, 07:22 PM   #9
CMcAllister
Liked 920 Times in 259 Posts
OP did not say where he purchased the VB.
Old 09-19-2024, 07:36 PM   #10
pmrphil
Yes, in his "class racer build" thread he had mentioned getting a package delivered from Broader Performance.
Phil Molski
PMR Performance
S/C 1623
