Old 08-24-2024, 06:35 PM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Ppp shifter clean and relube?
What you and a few others here didn’t do was reply to the OP’s question rather you reply with stupidity!
Old 08-26-2024, 07:57 PM   #2
CMcAllister
Liked 920 Times in 259 Posts
Originally Posted by 1320racer View Post
What you and a few others here didn?t do was reply to the OP?s question rather you reply with stupidity!
OP's question said 'visibly there?s a bit of a build up of crud on the shifter mechanism. Will give it a clean, what are you guys using to relube it?'
If mine had a build up of crud on it, I would clean it too. A thin film of grease, maybe a synthetic like Amsoil would be fine, but would attract dirt, requiring it to be cleaned again at some point..
A dry film lube should also be okay. Not a lot of pressure on those parts. just need to work smoothly.
