#1 | |
Liked 869 Times in 165 Posts
Now, I?m not sure if I?m just ignorant, oblivious, etc, but I don?t understand the issue of having a brake pressure switch active during the run. My 2 step is activated at 600psi. More than likely, if you?re using more than 5-600psi on a run, you are probably not going to be under power, and probably close to locking up the front brakes. To the best of my knowledge, if engine rpm is above the 2 step rpm, ignition will be cut completely.
1189 F/SA Defunzalo Racing Enterprises |
Liked 557 Times in 217 Posts
Makes sense about the brake pressure switch being active down track and not triggering the 2 step because you're not applying enough pressure to trigger it....
The info I've gathered here has helped Thanks...
Liked 880 Times in 311 Posts
If you don't have some way to deactivate the brake pressure switch down track in theory it could activate the 2 step when you do any hard braking.( dumping, hard backing into, ect) Depending on when, where, and how you hit the brakes that activated the 2 step it could be said you were activating a down track stutter device. I would hate to have that discussion with NHRA Tech. Some sort of deactivation switch is the route that might be all around the best and safest.
.02 for free
Adger Smith (Former SS) |
