#1 | |
Liked 75 Times in 28 Posts
Liked 27 Times in 19 Posts
Liked 103 Times in 25 Posts
Call Mike Schaefer at The Mod Shop - Lakeview, OH
He builds some awesome headers. He built the headers on Doug Duell's stocker and his SS challenger for reference. 937-935-9898 He has done a lot of work for me in the past. Great guy to work with. Casey FJ |
Liked 73 Times in 37 Posts
Does equal length mean equal flow and pulse timing?
Seen a championship Pro Stock with unequal length primaries |
Liked 759 Times in 379 Posts
equal length in our cars, cars with the firewall in the stock location, stock frame rails, etc. means sacrificing fit, ease of installation, spark plug access, ground clearance and in some cars, having to remove and or cutting the inner fender wells all for nothing on the time slip.
Liked 70 Times in 23 Posts
I just went through this in my Cavalier. I ended up with equal length and in firing order. There was no way I could get the length I thought it needed with the tight space. So I had him put the proper collector length collector and connect the flange.
I will say this. Equal length tubes with a LS firing order (SBC), makes a crazy looking header. Have pics if interested. |
#8 | |
Liked 269 Times in 99 Posts
There are many who will repeat this concept that headers don't mean anything on the time slip. It depends as always. Had a decent set of headers we made then had a custom set made for the engine combo picked up several MPH and decent amount of ET back to back. Friend of mine went from a set of box headers to burns stainless design and set of their collectors picked up good amount of ET and a few MPH. They were told clocking the primary tubes was more important than equal length plus avoiding sharp/tight turns was also. Depending on how far out to lunch your present set is you could pick up a lot!
