Old 05-21-2008, 10:02 AM   #1
chris3racing
Default Slicks - Tubes or Tubeless
I am debating installing tubes in a new set of slicks. 29x 10,5 M/T. M/T "suggests" a tube for the tires which are not listed as tubeless. I have been running tubes in the old set of slicks. Have been told it is safer not to have the tubes.
Do you run tubes in the slicks? Do you run "racing" tubes? Do you run screws in the slicks with and without no tubes?
chris3racing is offline   Reply With Quote
Old 05-21-2008, 11:10 AM   #2
SSTRACER323
SSTRACER323's Avatar
Send a message via Yahoo to SSTRACER323
Default Re: Slicks - Tubes or Tubeless
Chris
I run S/ST with a 64 Nova 3000 lbs with driver
I run Hoosier 28x10.5Wx15 with tubes and i screw the tire to the rim
The car handles better and is more consistent. I run the M/T tubes
I have the stock suspension on my car and it made a world of diff going to the tubes.
Just my opinion
The Doughboy
Lee Lones
S/ST 323L
SSTRACER323 is offline   Reply With Quote
Old 05-21-2008, 01:33 PM   #3
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
You have to run screws when you have tubes is what I have been told by my Hoosier guy. He doesnt recommend running tubes with their tires, and I would say it is probably the same for M/T. He actually pushed me away from the idea of a tube when I had thought about it over the winter.
Anyone know about the M/T with a tube?
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 05-21-2008, 02:58 PM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Its more of a personsal choice. I have run my car both ways. There seems to be no difference. If you run the tubes you will need the wheel screws. No screws w/o tubes. There is no reason to run the tubes unless you have a set of tires that leak air real bad. The only tires that I have had trouble with air lreakage was Phoenix. I have Mickey radials now w/o tubes with no problems.
Mike
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-21-2008, 04:04 PM   #5
SSTRACER323
The reason i went to tubes was the car was very inconsistent in the 60ft.
A good friend of mine was having the same problem with his 71 El Camino
after many changes he put in tubes and problems solved.
I started with Mickey and tubes and ran 12.5 lbs of air
i have a 64 Nova with leaf springs and slapper bars.
I run 4.56 rear gear with a glide and i leave at 4500 and go on the stop at .300 out
i went a 1.67 60ft in Norwalk this weekend. I have gone 1.38 60ft wide open at Rt 66.
I know run Hoosiers and still use the tubes and the car is very consistent.
I do run more air in the Hoosiers, now i run 13.5 air.
They helped me lots... maybe it is just me..... but if it works stay with it.
The Doughboy
Lee Lones
S/ST 323L
Old 05-21-2008, 06:23 PM   #6
Ed Wright
Ed Wright's Avatar
Years ago several of us tested that and all picked up MPH running them tubeless. I use 10.5" X 30" Hoosier radials now. They don't leak, I use no screws, and it goes 1.31 to 1.32 in 60' all the time.
Ed Wright 4156 SS/JA
Old 05-21-2008, 09:51 PM   #7
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
We run tubes,natural rubber.We also use rim screws.Our tires' sidewalls do very well as does tire wear.Running Phoenix tires,Firestones before that.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 05-22-2008, 12:28 PM   #8
Dave Goob Cook
Dave Goob Cook's Avatar
I would never run a tube in a car that goes over 140, other than that, it's preference, but I like running tubeless.
Dave Goob Cook is offline   Reply With Quote
Old 05-22-2008, 11:28 PM   #9
Ronald Urquhart
Liked 77 Times in 39 Posts
Smile Re: Slicks - Tubes or Tubeless
If a tube tire ruptures it can go instantly flat, usually a tubeless goes down slow.
Ronald Urquhart is offline   Reply With Quote
