Liked 56 Times in 31 Posts
I am installing a Moroso Accumulator in my stocker and am looking for a cheaper option than the Moroso or Canton solenoid valve to activate it.
Has anyone used anything else or are these two the most reliable options out there? Thank you in advance.
Thomas NHRA 1959 D/SA |
Liked 125 Times in 59 Posts
My opinion having the Moroso valve, it's the best option. You could just use a ball valve and turn it on in the morning and off before shutting down at the end of the day. Cheapest option but not near as effective as pre-oiling at every start up.
Liked 132 Times in 44 Posts
Thomas, You have a PM.
Div 3 Sales, Service and Tech for many manufacturers |
Liked 759 Times in 379 Posts
Banned
Liked 179 Times in 89 Posts
Because you can run a lower oil level in the pan and still be safe.
I don't believe in prelubing an in service engine, I'll start the engine with the valve closed then when the engine is warmed up slowly open to avoid a sudden drop in oil pressure and then leave the valve open the rest of the day |
You must know something this world champion and his top in the class engine builder don't
Yep, no accusump, how does Tilburg do it? ![]() ![]() Nice job guys! |
#9 | |
Banned
