Old 05-22-2024, 05:27 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default one or two batteries?
SS/GT cavalier...not sure which way to go. any advice please...i plan to run an alternator.
Old 05-22-2024, 07:02 PM   #2
GTX JOHN
Default Re: one or two batteries?
I you need the weight anyway = Why not run a
second battery. We do in our cars.
John Irving
741 Stock
741 Super Stock
Old 05-24-2024, 05:58 AM   #3
jmcarter
jmcarter's Avatar
Liked 3,199 Times in 977 Posts
What’s nice about GT is class flexibility, if you need the weight then what John said. If you’re looking to be able to move up in classes occasionally then it’s a lot easier (and cleaner) to just remove weight bars.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-24-2024, 06:11 AM   #4
richie 2
would any ony have a battery cable diagram to hook up two batteries using charging lugs and required kill switch in the system...tks !
Old 05-24-2024, 10:12 AM   #5
Jim Caughlin
Liked 805 Times in 245 Posts
I totally agree that if you need weight, might as well be a second battery. One piece of advice that I learned the hard way, between races, separate and load test the batteries individually. If one of the batteries goes bad, it will take the other one down with it.
Jim Caughlin is offline   Reply With Quote
Old 05-24-2024, 01:15 PM   #6
Keith 944
Keith 944's Avatar
This is absolutely correct!
if you must run two batteries consider running an isolator you could even put a switch inside the car in case one battery goes dead. Hit the switch and you’re up and running.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 05-25-2024, 08:22 AM   #7
Liked 10,779 Times in 2,240 Posts
We run two batteries in the Cuda each weighing 11.5 lbs one in stock location one in the trunk. We lost a little weight off of the front. Dumbo only has one in stock location.
Old 05-26-2024, 11:01 AM   #8
richie 2
looking for wiring diagram for this application if anyone has one please
