Old 05-21-2024, 03:23 PM   #1
MR DERBY CITY
Liked 8,217 Times in 1,537 Posts
Default Re: Is a 3-step bad?
I use a limiter in the water for protection . I have never had an issue in over 30 years . On the other hand Buddy Morrison swears that they are NOT a good idea to use in the water…..I have a feeling that your limiter is wired in with the line loc …That is a VERY bad idea …. When you release the line loc button you have no protection coming out of the water …..perhaps this is when you damage your parts ????
Old 05-21-2024, 03:41 PM   #2
pmrphil
Liked 397 Times in 153 Posts
I'd mention to Scott about breaking studs when still using a girdle - something is NOT correct. I have only seen that happen when using an incorrect (wrong) girdle for the stud spacing or, as was said, a geometry issue. Scott's a smart guy, give him a yell. Tell him I said "Hi".
Phil Molski
PMR Performance
S/C 1623
Old 05-21-2024, 04:04 PM   #3
JP1738
JP1738's Avatar
Liked 1,325 Times in 360 Posts
He's well aware of the issue, I show up at his shop to buy whatever needs replacing when it happens. He has said I should really consider going to a shaft rocker as the hp I'm making and rpms I turn are not really friendly to a conventional headed 383 with Brodix Trac 1 heads. I think I'm going to save that money for now and spend it when I can get my hands on a decent set of 18 degree stuff. I'd like to go full shaft at that point.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
