Old 04-16-2024, 10:53 PM   #11
Bob Sherwood
Liked 388 Times in 60 Posts
Default Re: 402 stocker engine
Do you know what brand and material the sleeves are ?? curious -- thanks
Bob Sherwood is offline   Reply With Quote
Old 04-17-2024, 07:45 AM   #12
Alan Nyhus
Liked 799 Times in 236 Posts
Jim, what are the leakage numbers cold and hot? -Al
"That'll never work....."
Old 04-17-2024, 11:49 AM   #13
Jrh5220
Liked 30 Times in 19 Posts
Question Re: 402 stocker engine
Bob they are cast iron. Have used them several times with no problem.
Jrh5220 is offline   Reply With Quote
Old 04-17-2024, 02:21 PM   #14
Jrh5220
Jim, what are the leakage numbers icold and hot? -Al
1 :7.5;3:7 5:4.5 7;6.2%. 2;5 4;8.5 6;8.5 8:5 %. Cold. H 1:5.25 3;4.25 5: 4. 7: 4.25. 2 3.25 4:4.75 6:4 8:4 %
Old 04-18-2024, 11:34 AM   #15
Jrh5220
Originally Posted by Henrys Toy View Post
Good morning to all,
Since you recently had this engine honed and re- ringed it, have you made any full power pulls on a dyno ?
It'll take a couple of pulls to get the rings to seat. Running at Idle or above Idle won't seat the rings.
Also what shape were the ring lands in ? If they have a excessive amount of play ( up & down) they won't seal either.
If you haven't run this engine on the dyno, I would, then make at least 4 or 5 full power pulls and that should get things in order.
Good luck with your adventure and keep us posted with your results.
Respectfully,
Henry Kunz 1534 H/SA
Henry the pistons are new lands are good,this is the second set of pistons had the same results. Here in South Dakota the dynos are few and far.
Old 04-18-2024, 07:23 PM   #16
Not having smoke from the headers simply means there's not a lot of oil getting into the combustion chamber, by the oil rings or the valve stem seals.
Smoke from the valve covers is a sign of blow by, or oil temperature problems. Blow by will actually blow the oil ring out against the cylinder walls, and stop oil from getting by. With good quality modern rings, odds are your problem is the hone, or what you're doing to assemble the engine.
Call Keith or Kevin at Total Seal.
The proper way to test cylinder seal is with a blow by meter on the dyno, with a Dwyer guage, there's no real substitute There's a video on youtube, by Lake Speed Jr.
Old 04-18-2024, 10:27 PM   #17
Bob Sherwood
Alan -- what are you thoughts or results on using sleeves in BB blocks ??
Old 04-18-2024, 11:19 PM   #18
Jeff Stout
Liked 704 Times in 281 Posts
Not sure if anyone else ask this. Do you know the tension on oil ring?
The other would be seating the rings. Either on a dyno if in car then maybe get brake pressure as high as you can and run motor in gear as high as you can. If unable to hold in 1st gear try second gear. I had trans brake on my super stocker and it worked well on rebuild. Don't forget to remove rpm chip. Hopefully carb is not leaking when sitting and washing out cylinders.
Jeff Stout is online now   Reply With Quote
Old 04-19-2024, 05:45 AM   #19
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: 402 stocker engine
I was catching up here this morning and that suggestion is a good catch. I was about to say if the engine is broken in properly, that the problem could be "deeper" meaning you'll have to scrutinize all the parts much more closely. I did have a problem recently where the way the Mfg. cut the Second ring stack, the cutter let a burr on the back side of the ring - causing it to stick in the ring land. The engine wouldn't seal and did smoke. I'm not saying this is your problem, but I'm stating that going over all the piece's in the " system" need to be inspected. Had another situation with rings where they " micro welded " themselves in the top ring land causing the top ring to not seal. I'm bring up examples so you can take your engine apart and " inspect " each part. Without the parts in front of me its a little difficult to see for myself.
Keep looking - I'm sure you'll see the problem.
Respectfully,
Henrys Toy is offline   Reply With Quote
Old 04-19-2024, 09:30 PM   #20
We have had good luck. However, to be very clear, we use flanged diesel sleeves. I won't use a non flanged sleeve anymore, for anything. Flanged sleeves are a royal pain, especially if your block is already "finished", and you don't want to deck it much, if any. But properly installed flanged sleeves do not move, and do not distort. Also, a good quality sleeve is better material than a production block. Combine a quality sleeve with the modern diamond hone process as prescribed by guys like Keith Jones and Lake Speed Jr., at Total Seal, and you have the best possible cylinder.
