Old 04-26-2024, 07:53 PM   #1
SDT1DYI
Liked 456 Times in 148 Posts
Default Re: 402 stocker engine
Originally Posted by Jrh5220 View Post
How warm should the engine be? Before the shut down?
I assume it's an Automatic?
Get the motor up to 120-130 on jack stands. In gear , hold the brake , put it on the Convertor to load the motor maybe 5 6 seconds. 180- 190 temps cool it repete. Or take to the track and make 2 WOT hits.
Again, suggest that you use Maxima break in Oil.
Where is the timing set at? Locked out distributor advance? I would be very conservative with it. BB 402 Stocker start with 32 33 degrees go from there.
SDT1DYI is offline   Reply With Quote
Old 04-27-2024, 08:55 AM   #2
Ralph A Powell
Liked 227 Times in 138 Posts
When you doing all this have a blowby meter hook up to it. When we had our B-Dragster you could spin the starter and if the float moved in the tube there was blowby!
Old 06-04-2024, 11:49 PM   #3
Jrh5220
Liked 42 Times in 23 Posts
Cool Re: 402 stocker engine
Have not had a blow by meter in 20 years.this is the only the 2 nd engine I had do these,one was many years ago . Sold it I have race bbc for
Longer than care to remember. These is one is been the worst. I have had it apart 4 times hone it each time with the same results. The engine seem to leak fairly well 2.5 to 3.7 warm. Ran 10.64 at 128.00
Jrh5220 is offline   Reply With Quote
