Liked 3 Times in 1 Post
I have an L78 stocker.
My question is about using tool steel lifters on a cast iron cam. I have been told that you cannot use DLC coated lifters on a cast iron cam. That you need to use uncoated lifets on a cast cam. Is this correct? |
Liked 510 Times in 117 Posts
Hi Rick. In my spare I ran a Pppp lifter with a special coating that will work on a cast cam. After 75 runs cam and lifters looked like new.
68 Chevy11 327 F/S |
#3 | |
Liked 1,878 Times in 422 Posts
Correct. You absolutely cannot run DLC against cast iron. James Schaecter at one time was working with a company that coated both cast iron camshafts AND tool steel lifters. I have had 3-4 customers who have been very successful with that coating. I have only been using Trend lifters, my dealings with PPPC, or, actually, a customer's dealing with them, and my inquiry with them after the failure the customer experienced, turned me off of them permanently. I have been using Comp cams, and they have been nitriding my cams for me.
Alan Roehrich 212A G/S |
