#1 | |
Liked 1,868 Times in 436 Posts
They ain’t tearing down **** Nhra is more worried about you stickers … to not pay you than tech
james perrone 1290 STK |
Liked 154 Times in 34 Posts
NHRA would only have to threaten to do teardown on winners and RU, they could also just do a thorough technical inspection and look at electronics for the last 8 in the eliminator.
Liked 7,925 Times in 1,760 Posts
Or they could just go back to the old ruling requiring that a "data-logger" be completely disconnected during eliminations. That should be easy enough to check in the staging lanes.
Guest
Posts: n/a
[QUOTE=Billy Nees;692334]Or they could just go back to the old ruling requiring that a "data-logger" be completely disconnected during eliminations. That should be easy enough to check in the staging lanes.[/QUOTE
How do you separate the data recorder from the EFI on a new car? I would be more worried about ignition. |
#5 | |
[QUOTE=Barry Polley;692337]
Guest
Posts: n/a
But isn’t the data recorder part of Fast and Holley Systems?
Older cars yes I get that . |
Liked 870 Times in 165 Posts
[QUOTE=Billy Nees;692338]As far as I know, all aftermarket ECUs that are accepted by NHRA have built in datalogging capabilities. And, unlike a Racepak which cannot datalog without an SD card, ECUs have integrated memory, and don't need an external storage device for data acquisition. An MSD Grid is an ignition box that can also data log, and you can't tell someone that their ignition box can't be hooked up during eliminations. I know that with a Holley ECU, you can program it to begin data acquisition automatically, whether it be RPM based, TPS value, so no need to even press a button to do so. Unfortunately there is no one true answer to the issue at hand. Should the Grid have been allowed in Stock/Super Stock? IMHO probably not. If they outlaw it, there will probably be an angry mob, so that alone may deter the decision to take it away.
1189 F/SA Defunzalo Racing Enterprises |
Ok, point taken but can an "NHRA accepted aftermarket ECU" without a "grid" make elapsed-time altering decisions on it's own?
P.S., this is why Doug won't let me have my laptop!
