#151 |
Liked 346 Times in 126 Posts
#152 | |
Liked 561 Times in 138 Posts
Tim Stickles
Tim Stickles |
#153 |
Liked 759 Times in 379 Posts
what part of the TRUTH and the FACTS don't you like?
another who can't debate a different opinion so he resorts to name calling. sad! Come by anytime, my camp at Numidia's divisional includes, Fletcher, Biondo and Ken Miele so I'm easy to find. No one runs an accusump that doesn't have a low oil pressure oil, usually when braking! That's an oil control is! Again, the fact is the vast majority of stockers do not run an accusump! Last edited by 1320racer; 01-20-2024 at 08:47 AM. |
#154 |
Your Saturday morning "jerk off" perfection in motion video
![]() ![]() start at 4:00 |
#155 |
Liked 20 Times in 16 Posts
Ed, you are a knucklehead!
FWIW My little low horsepower engine does just fine for me and has for 50 years. No, I do not have oil pressure issues at all. 75 PSI on the leave and 65 PSI through the traps at 8100 rpm. That's good for my program. Your choices do not mean others should follow suite and the same for mine. What is good about this forum is for the most part (other than Knuckleheads' personal attacks) someone has learned valuable info by sharing our experiences. My wife restocked up on pop corn and beer so flame on!
Drew Wonderly SST 159 |
#156 |
says a nobody knucklehead and I don't have an oil pressure issue either
![]() I didn't attack you but your weak ego apparently has been bruised by the truth and the facts. ![]() Last edited by 1320racer; 01-20-2024 at 10:49 AM. |
#157 | |
Name dropper….typical from you.
Tim Stickles |
#158 |
wrong, just making easy for you to find me being that you want to make this thread about you and me
#159 |
Curious how a guy that has never raced in Stock or Super Stock, KNOWS that the vast majority of Stockers do not run an Accusump? Between being so busy signing autographs, patting himself on the back, and polishing his chrome coil springs, not to mention how to slow down his Big Name Pro Built engine enough, I doubt that you have spent much time looking under the hoods of "the vast majority" of Stockers at whatever track that you give the honor of gracing with your wonderful presence, let alone all the other Stockers in North America, to make such a bold statement. Virtually every Stocker in my area of Div. 1 , DOES have an Accusump on it. Maybe instead of talking about the "Big Name Professional" engine builders that you need to pay to build you a 500-600 cubic inch engine to run 10.90 with, using whatever fancy oil pan you (or more likely, your Big Name Professional tells you to use), you talk to the guys that are building 10 second 305s with iron heads, a Quadrajet, and a stock oil pan , for heavier cars, and ask THEM about oil accumulators in a Stocker. Or maybe, even with all your superior knowledge, you don`t even know what an Accusump looks like.
#160 |
Liked 10,804 Times in 2,245 Posts
Old car has an Accusump new car does not. During a freshen up in my backyard both engine bearings , 440 RB and 392 DP, look good. What I'm most happy about it the big end of the rod is still round. What I think is the biggest help in keeping the big end round is the clean neutral at the end of the run and engine shut off. It helps eliminates compression breaking of the engine.
I will install an Accusump on this years dyno session and install in the car to help on engine starts. I might want to install a sight glass on the pan to see where the oil level goes on a pull. I'm assuming the volume of oil in the accumulator and its pressure follows the engine pressure. We charge the bladder to 20psi. The only draw back I can think of is: three more places for a potential leak. |
