Old 01-19-2024, 01:49 PM   #1
pmrphil
Liked 346 Times in 150 Posts
Default Re: The Demise Of Class Eliminations
Round track racers around the northeast are required to have a screw in plug in the side of the pan so the officials can look at the crank, rod, and piston. Quick way to verify if the correct parts are in there. Just food for thought.
Phil Molski
PMR Performance
S/C 1623
Old 01-19-2024, 06:31 PM   #2
DG
DG's Avatar
Liked 446 Times in 97 Posts
I would much prefer them to put a camera through a cap in the oil pan to look around to verify no illegal grinding/holes in the crank, no aluminum rods and no lightened pistons. If things look questionable they can always have you pull a rod for verification. Its not perfect, but a simple approach to deter the most aggregious cheating. Some cars have incredible 60' times for their class that should raise the suspicions of NHRA tech, this is a tool to address potential problems.
DG is offline   Reply With Quote
Old 01-19-2024, 06:59 PM   #3
Bobby Fazio
Bobby Fazio's Avatar
Give em what they want...
https://youtube.com/shorts/wwEX40PSr...DPjIWcqA_MK-Gt
'65 Mustang SS/L & L/SA
Old 12-05-2024, 10:02 AM   #4
cummins
Liked 26 Times in 7 Posts
They must not run A windage tray
cummins is offline   Reply With Quote
Old 12-05-2024, 07:06 PM   #5
pmrphil
Correct, just a scraper.
Phil Molski
PMR Performance
S/C 1623
