Old 01-17-2024, 11:48 AM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Strange DA vs Viking DA for Wheelstand Bounce Control
you want Afco BNC shocks aka big nose compression
Old 01-17-2024, 12:44 PM   #2
El Duderino
Liked 48 Times in 20 Posts
Craig, I don't know which shock is right for you...I do know that I wouldn't be taking advise on front shocks (or anything else) from a know it all, .90 bench racer
El Duderino is offline   Reply With Quote
Old 01-17-2024, 01:37 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 879 Times in 236 Posts
Spend the money for a pair of Santhuff shocks . Yes they are $1400 but they will save your headers and oil pan and all the other wear and tear on the suspension.
They WILL control the bounce , Strange and Viking are not going to give you what you are looking for.
Old 01-17-2024, 01:51 PM   #4
cad
cad's Avatar
Liked 91 Times in 51 Posts
Out of the box BNCs will not be perfect. I sent mine to Competitive Suspension to be revalved.
Clark
Old 01-17-2024, 01:58 PM   #5
1320racer
1320racer's Avatar
Question Re: Strange DA vs Viking DA for Wheelstand Bounce Control
I’ve been using Afco’s BNC shocks for nearly 20 years. Their adjustment range on both compression and extension provides the ability to dial in the shocks perfectly for most applications and if they need adjustment, you don’t need anyone else but Afco to tune them.
Old 01-17-2024, 02:10 PM   #6
1320racer
1320racer's Avatar
Agree
Old 01-17-2024, 02:28 PM   #7
CraigG
Liked 8 Times in 7 Posts
Well I am not sure that the AFCO shocks come as non coil-overs as I am using the stock control arms and Landrum #180 5X18 springs.
Thanks
CraigG is offline   Reply With Quote
Old 01-17-2024, 02:30 PM   #8
1320racer
1320racer's Avatar
They do. The stock A arms, need a small modification for the shock body diameter and mounting. Go to www.Chevelle.com and search Afco BNC. You should find info and photos regarding the required A arm modification.
I had planned to install the BNC shocks in my nose heavy Chevelle which had 59% of its 3880 lbs. over the front tires, but I sold it months after this video
Old 01-17-2024, 03:39 PM   #9
Rick J
Liked 73 Times in 37 Posts
Listen to Tom
Rick J is offline   Reply With Quote
Old 01-17-2024, 03:53 PM   #10
Rick J
Thumbs up Re: Strange DA vs Viking DA for Wheelstand Bounce Control
xxx - sorry, double post
