#1 | |
Liked 929 Times in 263 Posts
Maybe your guy has an exclusive pan design that no one else knows about that 100% keeps the pickup submerged. Or uses an oil additive that works as well as the BG MOA they use for that demonstration where they run a small block Chevy for 20 minutes with no oil pan. And it lives. Point me to a prominent engine builder who has a good reason not to use one and I'll listen to what he has to say and weigh the options for myself. |
Liked 1,471 Times in 308 Posts
Guys, one of the things we have to remember, is that in the Super Classes
and big money bracket races, is that they build 30-40-50% more Horsepower than they need. In cases like that, there is no need, nor would it be prudent, to run low oil levels. In a combo like that, I would run at least 1 quart of extra oil, if not more. I will very shortly be schooled on why I am wrong. In 3, 2, 1.......... J.R. |
Liked 759 Times in 379 Posts
yep you're wrong, here's your schooling, I run 1 quart low in all my engines, now tell me why?
Again, I have yet to have any professional engine builder tell me, suggest to me, that I need to use an accusump with their engine, Last edited by 1320racer; 01-10-2024 at 06:31 AM. |
Liked 346 Times in 126 Posts
Maybe there are not that bright, still want to know who the these professional engine builders are. Or do they just exist in your mind?
There it is!! You run your engine a quart low?? Tell you why?? I need
much more information on your motor. Type, size, oil pan, any restrictors any where in the motor, heads, etc. Cam size, mm not lift, overlap. Oil pan manufacturers recommended oil amount, what you consider full, to get 1 quart down. Rocker make, valve springs, ring set up, etc. With most of those factors, I could attempt to answer your question. Thanks, J.R. |
You don’t need any of that info to understand why.
#7 | |
Mcfly, it’s now the year 2024 and the vast majority of class racers and bracket racers have their engines built by professionals so you either ain’t got the coin or your arrogance eclipses your ego, seeking validation from a few old men like yourself wanting a merit badge for assembling your engines, setting a few clearances, assembling a few parts and torquing a few bolts who call that “building” their engines.
![]() ![]() Last edited by 1320racer; 01-11-2024 at 08:43 AM. |
