Old 01-05-2024, 11:06 PM   #1
J.R. Haddad
Liked 1,471 Times in 308 Posts
Default Re: Accusump - pros & cons
Jason, I would like to have 1 to 1 1/2 quarts available.
Thanks,
J.R.
J.R. Haddad is offline   Reply With Quote
Old 01-06-2024, 10:06 AM   #2
Steve Grady
Steve Grady's Avatar
Liked 170 Times in 55 Posts
Thanks,
J.R.
Moroso has them available in 1.5 Quart and 3 Quart.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 01-06-2024, 10:17 AM   #3
J.R. Haddad
1320, I don't know if I'm trying to band aid anything, as much as trying
to be proactive. In Stock Eliminator, from time to time, you might run
less oil than normal. The reasons can vary, from trying to move up on
the qualifying sheet to gain an early bye run, to a heads up run where
you need a little more than you presently have. In these events, top
end braking can send the oil pressure down lower than anybody
should be happy about. I think I like the piece of mind of knowing
there is additional oil available if needed. Thanks for asking.
J.R.
Old 01-06-2024, 12:44 PM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
I'm well aware of stockers running even less oil than their normal 1 quart low. I'm also well aware of losing oil pressure when driving the stripe and I'm also well aware of the thousands of racers including stockers that do not, have never, run an accusump, myself included.
Old 01-15-2024, 12:47 PM   #5
Barry Polley
Guest
Posts: n/a
Wait what??
( myself included.
Old 01-15-2024, 01:37 PM   #6
1320racer
1320racer's Avatar
wait why again did you reply to this thread? Answer to engage me not to answer the OP's question.
Old 01-15-2024, 11:35 PM   #7
tstickff
tstickff's Avatar
Liked 562 Times in 139 Posts
Your a clown and should be embarrassed, you have made yourself look like a complete idiot…congrats!
Tim Stickles
tstickff is offline   Reply With Quote
Old 01-06-2024, 01:30 PM   #8
JGrossijr
JGrossijr's Avatar
Liked 463 Times in 60 Posts
One consideration regarding accumulator volume selection is that capacity does not necessarily, and in my experience never does, equal actual working volume. Engine oil pressure, valving, and accumulator air pressure will determine how much oil is actually held in the accumulator.
  • The higher the oil pressure the more oil that can be stored in the accumulator up to capacity
  • The more air in the accumulator the less oil that will be stored in the accumulator
  • In simple open or closed valving (mechanical or electric) the oil volume in the accumulator, and in the engine sump, will vary.
In my opinion Mike Mans nailed the best reason for an accumulator. You end with the ability to pre-lube the engine on every start-up, whether its been 5 minutes or 5 months. This is particularly important on an engine like an LS with a front-mount above sump oil pump.
Secondly the accumulator acts as an insurance should the oil pressure drop for whatever reason. This can be particularly important in those circumstances where you find yourself draining oil to a minimum level for that go-fast run.
Don't simply plumb an accumulator into your oil system and assume it is holding the advertised capacity. Doing so will like result in more oil than you want in the sump, and more windage. After you install the system run the engine up to maximum oil pressure, close the valve, and shut the engine off. Disconnect the oil line and discharge the accumulator to determine what the maximum amount of storage actually is in your application. Try this with different amounts of air in the accumulator and determine what the ideal amount of air pressure is for your application. This will help you determine how much extra oil to add to your system. Keep in mind this volume will change as oil pressure changes in a simple open/closed valving, therefore engine oil level will vary proportionally to oil pressure.
This is where the Canton EPC valve
really shines. When the valve is closed it continues to fill and only discharges when pressure falls below a preset point. The preset point can be controlled with a mechanical pressure switch as supplied, or from a programmable switch output from your ECU. In this scenario there won't any oil being pushed into the engine until pressure drops below your pre-set, and the maximum amount of oil will be stored in the accumulator at all times above the preset. The preset point is generally just below idle pressure. In this case as the engine goes through higher pressures at higher rpm you push more oil into the accumulator. After a burnout, or any other significant rise in rpm the accumulator will be as full as it's going to get, and it will hold that volume until pressure falls below the preset. Should a condition arise where oil pressure drops below the preset the accumulator is as full as it can be with the most pressure possible, so response is quick with good duration. You would be amazed the differences in discharge at different holding pressures.
FWIW - The most oil I have been able to get into a 3 qt. Moroso accumulator at 90 psi was 2.5 qts.
JGrossijr is offline   Reply With Quote
Old 01-06-2024, 01:40 PM   #9
1320racer
1320racer's Avatar
FWIW, I prelube my engines prior to the 1st start of the race day by cranking them until I have at least 30 psi oil pressure, after that I ain't worried and drive it like I stole it!
Old 01-06-2024, 02:32 PM   #10
Steve Grady
Thank you for sharing your Real World experience.
