Old 12-29-2023, 06:18 PM   #1
LS1Racer
LS1Racer's Avatar
Liked 6 Times in 6 Posts
Default Blocking IAC on LT1 and re tune
I have blocked the IAC ports in my LT1 throttle body and was wondering the easiest way to get the idle air back through to get the right idle. I was going to adjust the blades out with the adjustment screws and reset the TPS in the ECU to zero. Is this the best way to do it or is their a better way to accomplish this? I am running a FAST XFI 2.0 ECU. Also is their any adjustment to the fuel map necessary in that lower end of the map? I am running AlphaN and sequential mode. Thanks in advance for the help.
LS1Racer is offline   Reply With Quote
Old 12-29-2023, 07:07 PM   #2
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Default Re: Blocking IAC on LT1 and re tune
If you have gotten used to a motor with a properly operating IAC, they have a tendency to spoil you. They will maintain and KEEP that idle at setpoint. Not very keen on Fast. You didn't mention if your dealing with a Superstocker or Stocker. Without the IAC the idles are a bit more contrary on the SS camshafts with their low vaacum, but very tunable. Yes, you will need to run the blades open and reset the TPS, especially with the Alpha.The issue you could possibly have is after getting it happy... so it will idle when cold and going into gear nicely (depending on the convertor)..., as it warms up the neutral idle will go higher than most people like. I build advanced tables so timing will be pulled out and or put in to maintain the desired RPM. The Holley has what they call "Idle Spark" to achieve this, but it only will move it 8 degrees one way or the other. I like 14 to do so,and it takes an advanced table. (If this is on a Stocker, you should not have any issues). Maybe someone with Fast knowledge will jump in here and help.
Jeff Niceswanger 3740 SS
Old 12-29-2023, 07:25 PM   #3
LS1Racer
LS1Racer's Avatar
Jeff thanks for the info. Sorry, I forgot to mention it is a Stocker.There is a timing trim table for idle which allows up to 12 degrees adjustment related to target RPM vs Actual RPM. I can adjust with that I believe for temp variations.
Old 12-29-2023, 10:02 PM   #4
Jeff Niceswanger
You should be good. Set your base idol at 20- 22 and let the trim do its thing.
Old 12-29-2023, 10:36 PM   #5
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
You may also have to adjust numbers on the fuel map at idle. Generally adjusting the screw and/or the fuel map at idle you should be able to achieve idle.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 12-29-2023, 10:39 PM   #6
mike britt
Liked 66 Times in 31 Posts
I built an adjustable air bleed to screw in where the IAC goes so I could leave the throttle blade closed at idle.
mike britt is offline   Reply With Quote
Old 12-30-2023, 08:08 AM   #7
Liked 10,769 Times in 2,238 Posts
Might want to check with tech if the IAC adjuster replacement is below the throttle blades. The replacement could be viewed as an adjustable vacuum leak. Sometimes tech thinks a little differently than the racer.
Old 12-30-2023, 01:55 PM   #8
I got bounced at Englishtown, in the early days of EFI for this sort of thing. The car builder was using an auxiliary petc o ck bleeder to control the idle. The IAC was disconnected and dead closed.
Lang and co. had to call CA. for a ruling. They were told that the idle vacuum air had to be controlled by the computer, or not at all. It was okayed in Div 2 ,at that time.
My Escort has an idle screw added instead of the stop screw on the throttle blades.
(IAC disconnected) It works fine with the mild camshaft.
Old 12-30-2023, 08:19 PM   #9
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Thumbs up Re: Blocking IAC on LT1 and re tune
Just curious to why you remove the AIC and the benefits of this? I have Turbo Buicks and still use them with no ill effects. I know our cams are tiny in comparison to a stocker.
Thank for this post,very interesting.
The more people I meet the more I like my dog
Kevin
Old 12-31-2023, 01:37 PM   #10
LS1Racer
LS1Racer's Avatar
I can only speak for my case so take this for what it is worth. My idle would race sometimes and was extremely wonky. I probably could have tuned it better but have read here many times from respected racers to just unplug it or block it. I chose just to block it. I do have another TB that still has an IAC on it if I decide to go back to it.
