Liked 288 Times in 109 Posts
Racers,
I have heard the stories of running a BBC rectangular manifold on an oval port head, which is a huge mismatch. The stories relate how such a mismatch ran well. My situation is an LS3 head with a CDI intake that fits fine except the roof of the port. The port is about .080" smaller than the intake, at the top only. The engine is assembled except for the intake. If necessary, I can tape up and slightly the relive the top of the port. My question: do I need to relive the top of the port, or is it wasted time? |
By tha way, this is a 408 CI drag race engine, NA, carb., with expected output of around 725 horse on Methanol.
Liked 1,943 Times in 584 Posts
If I were in your shoes I would epoxy the intake to match the head.
Mike Pearson 2485 SS |
Mike, that is a reasonable idea, thanks.
Another thought, the CID intake is very tall and has a very large plenum. I have considered selling it and using a super victor. This engine is going in a 75 vette and the CID intake will require a sizable scoop to clear. |
Liked 759 Times in 379 Posts
Larry, I say no. That said, I think you know I ran that mismatch for years, using an Edlebrock RPM dual plane manifold atop my then 650+HP 468 and it ran great. Rich Biebel aka scdiv1 over at DRR built the engine and did the fitment of the manifold. Ultimately a Brandywine aka Larry Woodward, fully ported Weiand single plane manifold ran .about 02 quicker. Best Et with the dual plane was 10.11 and single plane was 10.07 in better air.
Liked 90 Times in 52 Posts
I worked at a engine shop in the 70.s & we took a GM aluminum BBC Rectangular manifold & filled bottom of the runners with epoxy & then matched up to oval port heads .. made more power than any other existing oval port manifold avail at that time
