Old 12-10-2023, 02:37 PM   #5
Liked 1,737 Times in 395 Posts
Default Re: Yella Terra shaft rockers
Yella Terra rockers are tentatively approved for NHRA Stock Eliminator.
Specific part numbers, which meet the NHRA rule requirement that no machining be required for installation, are accepted.
Contact Jim Petrakis at Yella Terra. Also contact NHRA Tech, with a specific part number for your particular application.
Note: These are NOT "shaft rockers" in the same style as the Jesel and T&D shaft rockers commonly used in Super Stock. These rockers bolt down individually or in pairs, to the stock, unmachined rocker arm bosses on the heads. They sit on "stands" in a manner similar to "pedestal" type rockers used on OE applications, and are secured by socket head cap screws, the lash is adjusted at the pushrod cup.
