Old 12-06-2023, 12:24 PM   #1
ShipC1970
Liked 30 Times in 11 Posts
Default Re: Ford 302 SS build
Mixing engine components does not make a hybrid. Using an engine by the same manufacturer that was not offered in your make-body is a hybrid.
Gotcha so if I run a 390 combo I could run in GT since the 390 wasn’t offered in the 70 mustang? What about a 68 302 then? I couldn’t run it in GT since the 302 was offered in the 70 mustang?
ShipC1970 is offline   Reply With Quote
Old 12-06-2023, 01:30 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Different year engine combo can run in GT.
Old 12-06-2023, 01:30 PM   #3
Mark Ugrich
Liked 71 Times in 38 Posts
Yes you can run the 68 302 in SS/GT. I think you want a J code 302.I believe that engine allows a holley four barrel.
Old 12-06-2023, 01:34 PM   #4
ShipC1970
Would I have to find a J code long block? Or could I just use a 68 block with the 70 heads? Or? Sorry all new to me!
Old 12-06-2023, 01:39 PM   #5
Mark Ugrich
No, you claim the engine as a j code and must adhere to the specifications for that engine. The people in tech check to make sure you’re legal, if they check.
Old 12-06-2023, 01:43 PM   #6
ShipC1970
Ok thanks for the clarification i appreciate it! I’m just torn between running a 302 or a 390. Car is already set up for 302 and I don’t really feel like going through the troubles for big block swap.
Old 12-06-2023, 03:43 PM   #7
James Hill
Liked 14 Times in 6 Posts
You can't get the Edlebrock Aluminum heads for the 390 any more so that combination would be out for me. The iron 68 heads are hard to find, but it's a good combo. The aluminum head 302 is easy to source parts. 64 289 rated at 203 is a good combo also. Your going to buy rods and pistons anyway, getting a stock crank done (from Castillo Crankshaft service which is near you) at a reasonable price.
James Hill is offline   Reply With Quote
Old 12-06-2023, 09:25 PM   #8
GTX JOHN
Castillo is in the process of retiring due to Health Issues.
John Irving
741 Stock
741 Super Stock
Old 12-06-2023, 03:44 PM   #9
B/S 428
Liked 154 Times in 34 Posts
There's a reason no one is running the 69/70 302 2bbl combo, the HP is 220, the carb is 1.08 venturi rated at 287 cfm, jmo I looked at doing this years ago and my math says you'd be lucky to run the index.. however the 68 302 rated at 207 with 68 cast iron heads, 4bbl Holley, GT SS is a much better choice..Brian Seaberg 627
B/S 428 is offline   Reply With Quote
Old 12-06-2023, 09:04 PM   #10
Liked 5,138 Times in 1,961 Posts
Wink Re: Ford 302 SS build
64-65 352 4 bbl
