07-21-2023, 04:17 PM | #11 |
Liked 236 Times in 44 Posts
Re: Stacker Trailer Question
Friend of mine, OCD dirt track racer, uses blocks under his chassis and then ties it down.
Next step for him is to tie down the rack that the car is sitting on. Yours may be better but he claims his moved more than the car. |
07-21-2023, 10:25 PM | #12 |
Liked 204 Times in 72 Posts
Mike Graham I just drove across I40 in AZ yesterday with my trailer. I don't know how your car is still in one piece. NM and CA are not any better. TX roads were better but no state knows how to lay pavement at the ingress and egress to a bridge. I swear my trailer had all six tires off the ground.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
07-22-2023, 09:31 AM | #13 |
Liked 9,534 Times in 1,977 Posts
The race car we carry on top. On the rear we use two non adjustable straps that surround and cross the center section. If the car is not straight on the lift one of the rear straps will be loose when the front is pulled forward and down. You have two choices re position the car or stop 20 miles down the road and re tighten the front straps. Due to the crown in the road the car always slides down hill, curbside. On the front I use four straps, two straps crossed tied to the Kmember and two lighter safety straps going to two 7/16 eye bolts to limit front suspension travel. After everything is tight we recheck at 50,75,100 miles until lit stops moving around. In the morning when tire pressure is lower retighten the straps.
If you want to limit upward movement turn buckles and pined blocks work. Also we strap down the lift at all four corners. Try to carry a spare strap for every position. Last edited by Larry Hill; 07-22-2023 at 09:33 AM. |
