Liked 1,354 Times in 413 Posts
I guess either the manufacture or someone has to submit something for the V6 combo. Surely not a "dime rocket" but the "new"Challenger is 15 yrs old. 50 yr old cars are good to go though.
Paul |
Liked 346 Times in 126 Posts
might not be a dime rocket, but if we can get them in to the guide, it would be a new source. it would be great to see the 6 cyl mustangs and camaros added too
Since Paul Wong and I got into building the 5.7 street version. I always wondered why the V6 wasn't in the books. Sure are more of those then Hemis I bet. The SOHC 3.5L has had some changes here and there. Don't go by me. I haven't researched it a ounce. I think it was 215 hp and thru the years was pumped up to 230. Get some generous NHRA person to start it out lower than listed. A real street car with some small mods (headers and what ever) might run index..
Paul |
Liked 66 Times in 31 Posts
How are you going to put headers on an engine with only one port per bank?
carefully?
Liked 38 Times in 17 Posts
I'm fairly certain the 3.5L used through 2010 had 3 exhaust ports in the head, it's the 2011-up 3.6L that doesn't.
K Danner STK 468 |
Not my concern either way. The SOHC engine has 6 exhaust ports if your worried. Your talking about a DOHC engine with one port.
#9 | |
Liked 776 Times in 199 Posts
Bret Velde 2003 ??/SA |
I had to look at it now that I opened my mouth. So hopefully I'm close. If not forgive me. The Dodge 3.5L SOHC is listed as 250 hp and ended in 2010 models. The 3.6L DOHC V6 is rated as 305 hp. 8 speed transmissions came into play 2015. The same 3.6L in a Charger is rated 292 (exhaust or tune better in the Challenger?). Now at the same time the 5.7 Hemi is rated at 376 hp and is in the book at 300. If either V6s were in the book, which they should be. I would think those combos should get the same percentage off on their advertized Hp ratings to start. Not like there is a mad rush to build street 5.7 Hemis either. Some younger folks like new cars. Me too!
Paul |
