Liked 8 Times in 2 Posts
Superflow 890 Dual-Eddy Current Dynamometer
HP Power Capacity (Acceleration/Steady State): unlimited/1600HP MPH Capacity : 200 MPH Roll Diameter: 42” Track Width: 40” to 96” Wheel Base: 98” to 149” Axle Capacity: 10,000lbs (Class 8 truck rearend) Control System : Automatic Load Control Power Requirements: 120VAC 60Hz and 240VAC 50-60Hz 20A Data Acquisition : Superflow Windyn 3.2 Operator Console: X-Console:displays data, load control, emergency stop Data Acquisition Sensor Box: multiple thermocouples, pressure, 0-5V inputs Purchased: 2004 Asking $30K OBO Hypertech selected the SF890 chassis dyno for easy of setup and repeatability. The 42” knurled rolls provide superior traction with minimal tire deflection for accurate and repeatable testing. Hypertech relocated to a new facility with limited space. This dyno is a duplicate to the SF in operation. Prior to the move, this unit was operating properly with no issues. The SF890 series is capable of supporting speeds of 200 MPH and 1000 HP. The maximum axle weight is approximately 10,000 pounds, the track width range is from 28” to 86”, and wheel base range can be adjusted between 98” and 149”. The flexibility allows for a full range of vehicle testing. Both RWD and AWD vehicles can be tested. The 890 series chassis dyno includes a center-mounted eddy brake for steady state testing, which can support unlimited HP during acceleration tests, and roughly 1600 HP when using eddy current motors as load. View in real-time torque/horsepower output, at steady and changing speeds. To instantly evaluate changes made to the engine fuel or timing maps. The Superflow Windyn Software can be operated using a laptop for in vehicle tuning or from a tuning station. 901-382-8888 ask for John or Amy |
