Old 03-09-2023, 10:51 AM   #1
Jim Hawkins
Liked 115 Times in 35 Posts
Default Mopar master cylinder question
Which port should go to the front brakes on the mopar/chrysler aluminum master cylinder?
I have seen this master on many cars and plumbed both ways. Mine is front port to front brakes. Correct?
Jim Hawkins is offline   Reply With Quote
Old 03-09-2023, 11:05 AM   #2
cad
cad's Avatar
Liked 91 Times in 51 Posts
Default Re: Mopar master cylinder question
That is how mine is plumbed.
Old 03-09-2023, 12:29 PM   #3
David Lee
Liked 346 Times in 126 Posts
do you use the one with the largest brake fluid capacity?
Old 03-09-2023, 01:28 PM   #4
Keith 944
Keith 944's Avatar
Liked 1,883 Times in 578 Posts
The larger Reservoir goes to the brakes that hold the most amount of fluid
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 03-09-2023, 02:09 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Per the instructions for a Strange Mopar style master cylinder. The reservoirs are the same size front and rear, however the piston volume is larger on from the port closest to the pushrod.
■ The outlet port nearest the pushrod supplies the most fluid volume and should be plumbed to the calipers requiring the
most volume. Typically a drag race only car will have the largest calipers on the rear, while a street driven car will have the
largest calipers on the front. Attach lines accordingly
Since most S/SS cars have the same calipers front and rear it really does not matter although I always plumb the larger section[ closer to the pushrod] to the rear brakes.
Old 03-09-2023, 03:29 PM   #6
Jim Caughlin
Liked 805 Times in 245 Posts
That's the way I have always done it but to be honest, I have seen a ton of cars that were done both ways over the years and it doesn't seem like it has had much effect either way.
Jim Caughlin is offline   Reply With Quote
Old 03-09-2023, 04:49 PM   #7
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Jim, mine is front brakes, front port.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 03-11-2023, 11:33 AM   #8
Eman
Liked 133 Times in 76 Posts
It's a straight bore MC so pressure has to be the same at both ports. The rear piston will move slightly quicker than the front one as they are tied together with a spring. The rear port will provide a little more volume so if you have front disc and rear drum plumb the rear to the front disc. On many MC's the one section will have a larger reservoir as that was the end that was plumbed to the front dis brakes as disc brakes are self adjusting by using fluid to fill behind the piston as the pads wear.
Old 03-11-2023, 04:48 PM   #9
CMcAllister
Liked 920 Times in 259 Posts
This is the correct answer. Especially for a 4 rear caliper set up.
And make sure there some sort of retainer, besides the rubber ring, to positively keep the pushrod in the MC.
