Liked 346 Times in 126 Posts
is 37 degree with just plain steel lines safe?
Liked 920 Times in 259 Posts
37 degree inverted double flare is used with regular steel or stainless tube with AN fittings and tube/sleeve connections.
45 degree is the common automotive SAE inverted hardware. AN stuff will be more money, but is worth it IMO. |
#3 | |
i was not aware that stainless could take a double flair |
I've done some nitrous plumbing in SS. It can be double flared if it is annealed. Requires a good flaring tool. Some people feel it doesn't need to be double flared for brake lines, although I don't agree. Probably overkill for most unless you want to polish it for a show car look.
I haven't used it in a long time. I prefer the old style "Bundyflex" zinc coated steel. Harder than the CuNi and green coated stuff. But not so much so that it is miserable to work. If appearances matter, it can be cleaned up with some fine scotch brite and WD40 to a nice satin look. |
#5 | |
i am using the bundyflex. |
Liked 327 Times in 121 Posts
Brake lines are a pleasure with this.
