Old 04-28-2008, 02:14 PM   #2
Liked 1,821 Times in 413 Posts
Default Re: Squeaky Brakes ?...
Wade,
Make sure you do not have a caliper bracket tweaked or cocked, that will cause the pads to run with a trailing or leading edge touching, and making them squeak. An easy test is to look for dust build up on a pad. Retorque all your fasteners as well, you may want to change the order you torqued them in.
