Actually, on many Ford unibody cars like Mustangs and Fairlanes, the factory gas tank drops into a large rectangular hole in the trunk floor, and the top of the gas tank IS the trunk floor.
#2 | |
Liked 72 Times in 36 Posts
Kenney Kelley |
Liked 8,260 Times in 1,543 Posts
Cut the top of the gas tank ..GEEZ. I don’t think so ……
Liked 727 Times in 221 Posts
Any time you cut up a gas tank, an explosion hazard is created. The best bet would be to fabricate a replacement panel from 18 gauge steel that would replace the OEM tank. Be sure the tank is outside when any cutting or welding is being done in the shop. Fumes can travel quite a ways and carry a flame back to their source and do damage.DON'T cut or weld on the gas tank itself.
Liked 711 Times in 205 Posts
GAS TANK
Must be correct year, make, and model for car used, with stock fuel inlet and outlet locations. Must be in stock location; fuel line and pickup may be resized. Fuel cell permitted; maximum capacity 16 gallons. If fuel cell is used, OEM gas tank must be removed, and a firewall of minimum .032-inch aluminum or .024-inch steel must be installed to totally seal driver compartment from fuel cell. Trunk floor may be modified to accommodate fuel-cell sump. STK Section 11A, page 5 Stock Cars Where OEM gas tank is in the trunk floor, area occupied by OEM tank may be replaced with material equal to or heavier than OEM floor. If OEM gas tank is used, it must remain unaltered. I read that to say if you use a fuel cell the gas tank must be removed. In the Ford a new trunk floor needs to be used and it can be modified for fuel cell sump.
Mike 7570 A/SA |
#6 | |
Kenney Kelley Last edited by Kenney Kelley; 01-16-2023 at 12:50 PM. Reason: spelling |
#7 | |
Used the relocating Moroso rear spring hangers, and the welded new sides to the narrower stock tank. First thing was to flush the empty tank with water, several times . Then cut the ends off with a jig saw, leaving as much water in as possible. No room for fumes = no explosion The opened tank would still sit outside for a few days, before tig welding the sides on. In this case though, I'd just buy a piece of sheet metal and tech screw it down. No need to make a production out of this ;-)
Liked 250 Times in 49 Posts
Neighbor of mine used the exhaust method to clear a slightly larger tank.. They burried him four days later. Fire and/or sparks near gas fumes can be deadly.
#9 | |
Liked 71 Times in 38 Posts
Actually i’ve seen just the opposite. Section the tank and use the lower half. From under the car it looks like it still had the stock tank, then mount the fuel cell inside on top.
