Liked 779 Times in 209 Posts
In need of some help.
What size rear came in a 87 Z-28??? I'm sure it's a 10 bolt, but what size, 7.5, 8.2, 8.5??? Does anyone have one for sale for a Stock Elim. car Spool, Axles, Gears. let me know what you have... Also, if anyone has 305 parts, let me know.. Thanks |
Liked 113 Times in 9 Posts
Pistol Pete, I have lots of spare parts that will make that camara fast, Barry has the same parts, come on over to the other side and let it all hang out. Coming to the BBQ?
Joe DeMarzo 1317 STK |
Factory rear was the 7.5". There are things you can do to make these rears live longer but gear choice is very limited. Best bet is to get a Moser or Strange 12 Bolt for it. Better choice of gears and will last
Doug Blackley 1697 STK |
Joe, What'ya mean you & barry have spare parts?? you never ran a 305.
Where's the BBQ at ??? ![]() ![]() Come on over to what side????? Doug, Can you get a 513 gear for that 7.5 rear??? i'm on a tight budget here..... Thx |
No on the 5.13's. Limit is 4.56's for the 7.50 rear, you'll have to run a 28" tall tire to be close to the 5.13's with a 30". I ran the original rear for a couple years before upgrading.
Doug
Appreciate the input, your probably right to go to the 12 bolt right off the bat. I thought i could get away going the cheap route. I do not want to spend money twice on building this car... What class do you run???? Thx |
Last couple years I've run J/SA but this year I'm looking to move up classes.....not sure which.
Doug
Would a rear from a 94 Camaro fit in a 87?? i think the 94 is a 7.5 also, but i do not know the lentgh of the axles... Also, what does your car weigh with driver for J ????? what hp head is your 305 motor ???? Are you running the Englishtown Nationals in June??? Thx |
Not positive on the actual length of the 4th gens but I think their the samesince the Strange unit fits 82-02. I'd still suggest just upgrading ahead since you will have a much better choice of tire/gear combos to try.
In J the minimum is 3345 with the driver. I run the 150/254 combo. No on E-towns nat'l this year,next outing likely will be the Island Open next month.
Doug
I see your from Mass., I'm friends with the Parker Bros., there a riot to be around. Are you running the Atco points race in June ????? Do you know anyone looking for a nice strret car?? i have a 94 Camaro V6 automatic with air. Very Clean in & out & Very well maintained, adult owned since new.... Sell my car & i'll give you $100. Asking $2200. THx |
