Old 10-02-2022, 08:33 PM   #1
1347
1347's Avatar
Liked 1,015 Times in 278 Posts
Default Re: 1967 belvedere claimed as a gtx.
not sure how much you have to take off a 906 head to turn it into a closed chamber head, but won't that effect piston to valve?
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 10-03-2022, 02:17 AM   #2
GTX JOHN
Absolute it will!
I sold two nice sets 915 that were nice Pairs this week = $400 pr.
John Irving
741 Stock
741 Super Stock
Old 10-03-2022, 07:43 AM   #3
Steve Stasko
Liked 286 Times in 146 Posts
Speaking from experience... If you take the 906 down to closed chambers, it's not a matter of if they will crack between the cylinders, but when. I suppose in a Stocker though, cutting the surface down to 74 cc, it's still going to leave a little of the chamber in the head.
Paul is pretty close on his numbers. The last 906 I measured was 85-86cc, and I know it had a light cut. If I was going to cut an open chamber head down though, I'd use a 452.
Old 10-03-2022, 12:31 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
There are two versions of the 915 head, the GTX got the 915 HP head which has a larger exhaust valve . If you are having problems finding 915 heads , Mopar also used them on the marine version of the 426 wedge in 1968.
Old 10-03-2022, 12:46 PM   #5
GTX JOHN
You canput 1/75 Valve in the 1.60 Head.
You are not going to run stock valves anyway.
The 1.60 head fit more applications that are run in stock
currently.
The 1.75 Heads have HP stamped on the front flat surface.
John Irving
741 Stock
741 Super Stock
