Old 09-30-2022, 09:43 AM   #1
Run to Rund
Liked 54 Times in 27 Posts
Default Re: 8.8 Ford rear pro drag gear set
You can probably find a commercial housing set up the way you need it, at a moderate price. Another thing about the 9" is that you can go way overkill for almost the same price as setups with less strength--31 vs. 35 spline axles, 28 vs. 35 spline pinion, etc.
