Old 09-11-2022, 05:36 PM   #1
Altronics
Sponsor
Altronics's Avatar
Liked 63 Times in 11 Posts
Default Re: Impact of water grain and % oxygen
Originally Posted by Charles Stewart View Post
Just want to understand and input will be really appreciated.
What is the relation between those ?
More grain of water per pound of dry air mean less air molecule in that pound of dry air.
I know that some area own more % oxygen than other (degree of pollution, tree, altitude, near ocean...) But do they serve the same goal in weather calculation or they have their own impact on calculation.
PerformAIRE Weather systems calculate Density Altitude(Air Density) and is the only system that actually measures oxygen content, by use of an optional Oxygen sensor. The Oxygen percentage is influenced by the surrounding area (Pollution, Vegetation)
When we talk about Density Altitude it is a calculation based on the Temperature, Humidity, and Barometric Pressure alone in the air. Typically, we ASSUME a constant percentage of oxygen (20.90%) within that density. The only way to determine the actual percentage of oxygen and therefore the actual amount of oxygen per volume is by specifically measuring the oxygen level independently from the temp, hum and press.
An internal combustion engine does not burn "air density", it burns Oxygen with Fuel to create power. Knowing the actual amount of oxygen is very important and is the main factor a PerformAIRE weather station is providing to determine the performance.
Secondary, the amount of water in the air density also influences the performance of an engine. Generally, the more water in the air, the worse it is for performance. Not only is it displacing the amount of oxygen but it also can dilute the fuels energy potential.
Water grains is an ABSOLUTE calculation of the amount of water in the air. Unlike RELATIVE humidity (water % based on temperature), think of grains as the weight of the water in the air.
Without getting into too much detail, the PerformAIRE systems use Patented measurements and algorithms to determine not only the air density, the amount of oxygen, the water content, and how that all effects the engines performance.
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
Old 09-11-2022, 08:43 PM   #2
Ralph A Powell
Liked 225 Times in 136 Posts
It’s is the system to with the optional Oxygen meter.
Old 09-12-2022, 10:16 AM   #3
Charles Stewart
Liked 755 Times in 213 Posts
"Typically, we ASSUME a constant percentage of oxygen (20.90%) within that density. The only way to determine the actual percentage of oxygen and therefore the actual amount of oxygen per volume is by specifically measuring the oxygen level independently from the temp, hum and press."
Thanks Mr. Bartoli for your precious input.
That was exactly the purpose of my question. I doubted something was missing in my weather calculation and I was also assuming a constant percentage of oxygen.
keep on coaching us...
Charles Stewart is offline   Reply With Quote
Old 09-13-2022, 08:14 AM   #4
Ralph A Powell
When we were monitoring Oxygen at the track we were at the Texas Motorplex on Saturday the wind was blowing from Dallas towards the south on Sunday morning it had changed to coming up from the gulf with same Baro and temp. On the Oxygen meter there was a 1% increase oxygen available and it showed in performance of Fuel Cars and Pro stock.
Old 09-16-2022, 10:07 AM   #5
Charles Stewart
I must add this previous post from Don Sofranko to this fact:
Re: "Live From" Indy US Nationals The Big GO 2022
Just a curious question after watching the big race from home on NHRA tv
As a past racer at the big go, its always a challenge with the big delays in hours or days between rounds. I was amazed that a bunch, if not all the guys on Monday slowed more than expected, from the early Monday R4 to R5 (3:30 PM) in super stock, and also similar in R5 to R6 Stock. It seems like with all the modern weather stations, and other data that it would have been detectable, to see a slowdown.
Am I wrong or is there another reason for everyone missing the dial by what looks like .03-.04?
Why do the modern weather stations not always tell the picture?
This was from early Monday to the 3:30 afternoon round
Old 09-19-2022, 06:29 AM   #6
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I’m curious if there were any other apparent changes when this happened. Especially pertaining to Grains/Dew Point.
S/ST 51
S/C 53
Old 09-19-2022, 08:20 AM   #7
Ralph A Powell
No but you could haze coming out of Dallas
Old 09-13-2022, 10:15 AM   #8
Charlie Yannetti
Liked 192 Times in 83 Posts
I was going to suggest a decent weather station, but Altronics beat me to it.. I have a Crew Chief Pro system in my trailer, and couldn't believe all the options available for predicting the weather, pertaining to throttle stop and ET predictions.. you will not be dis-satisfied making that move, if you haven't already..
I always looked at density altitude, (DA), while trying to dial, but learned that it is the formula that goes into arriving at the DA that is more important.. that being said, I'll tell you that grains of water and vapor pressure are pretty important.. the higher they go, the slower you go..
Charlie Yannetti is offline   Reply With Quote
