Old 08-30-2022, 02:25 PM   #1
nhramnl
Liked 358 Times in 83 Posts
Default Re: Koni Spa1 Drag Shocks Users/ Recommendations
I have never gone wrong following Pustelny's advice: Start both fronts and rears in the middle of the range and tune from there according to what the 60-foot times tell you. You'll usually be fairly close on the back (starting in the middle) and you'll probably end up loosening the fronts a bit. In my humble opinion, there is no setting that works for all (or even most) cars. Your car wants its own setup.
Old 08-30-2022, 05:21 PM   #2
CMcAllister
Liked 928 Times in 263 Posts
Very true. I like to use aggressive set ups and use the shock to control the housing or the front end. And I like to try to run the rear shock as tight as I can. Some can use shelf shocks, most I see can benefit from something else.
If you get to dead tight, or one notch from dead tight, and the car wants more, it may be time to step up on the shock or shock valving. I want to run the shock somewhere in the middle, so I have room to adjust either way, and still have it as tight as I want.
SPA1 is an old set up. Things have changed. I've taken SPA1 dampers off, replaced them with custom stuff, or an AFCO Big Gun shock, and made for a very different car. Front and rear.
