Old 04-15-2008, 08:21 PM   #2
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Allison Transynd
the allison transynd is designed for allison transmissions and by using the transynd in there trans missions will able you to purchase extended warrantys it must be good to offer that,i had a caravan that i used regular dextron in and i swore i blew the thing up, real hard shifting ,shifting late,banging converter,changed back to the correct chrysler trans fluid,trans went back to normal operation,we usr the transsynd in all of our over the road coaches and the transmissions last 500,000-600,000 miles they wouldnt make it 250,000 other wise
now your car transmissions operating range should be about the same as the engine,you mite want to go back to the chrysler stuff,i know i had to,that trans lasted 173,000 miles before i had to go thru it
gmonde
