Old 03-21-2022, 07:28 AM   #1
Plyguy63
Liked 7 Times in 5 Posts
Default VP C12 in a metal gas can
Was thinking of buying a five gallon Class 1 metal safety gas can as they are DOT approved. Am using C12 and wonder if that could affect C12 in a fuel check. Those gas cans are galvanized and could it affect C12? I do have plastic fuel jugs, but those are not DOT rated, let alone some not even rated for fuel. VP comes in 5 gal metal cans, but is not a safety container. Thanks, just curious.
Plyguy63 is offline   Reply With Quote
Old 03-21-2022, 12:22 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 965 Times in 306 Posts
Default Re: VP C12 in a metal gas can
C12 is pretty stable fuel. Keeping it in original VP can sealed it will stay good over a year.
Glenn Briglio is online now   Reply With Quote
Old 03-21-2022, 01:02 PM   #3
Jim Caughlin
Liked 791 Times in 241 Posts
I realize that the plastic jugs that pretty much everyone uses might not be DOT approved but if they are a problem for storing fuel, the world is in a world of hurt, we should be having explosions on a daily basis as there are thousands of them out there.
Jim Caughlin is offline   Reply With Quote
Old 03-21-2022, 01:41 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 274 Times in 76 Posts
A lot of us buy our fuel in 55 gallon barrels and transport what we need per race. I have been transporting multiple 5 gallon containers in VP plastic jugs for years. Some transport the barrel. I would keep it in the 5 gallon pale it came in.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-21-2022, 01:51 PM   #5
Plyguy63
Not worried about explosions and the like, I would use it to store fuel in my trailer going to events. Just would like it in a metal container in case of an issue while towing. Nothing against plastic fuel jugs, that was not my intent. I own some like every other racer.
Old 03-21-2022, 01:57 PM   #6
Jim Caughlin
Sean
Same with me, I have a 55 gallon drum of C16, transfer what I need for the race into plastic jugs. As leaving fuel in the heat and/or sunlight, I transfer the fuel back into the barrel (which is kept in a cool area) when I get home. Don't keep race fuel in your trailer between races as it can get crazy hot in an enclosed trailer baking in the sun. For the record, C12 is probably OK longer term but C16 degrades pretty quickly so I never keep it more than 1 year, I learned that lesson the hard and expensive way.
Old 03-21-2022, 03:24 PM   #7
Jeff Stout
Liked 704 Times in 281 Posts
Dont pull out the funnel type opening on 5 Gallon cans. If lifted a few times they will crack and will not keep fuel in good shape
Old 03-21-2022, 03:48 PM   #8
Rory McNeil
Liked 1,089 Times in 298 Posts
I don`t know if they still do this, but several years ago, at a NHRA National Event, I took 2 of my old 5 gallon VP cans to the VP trailer to fill them up, and they removed the old opening/funnel metal rings, and installed new ones.
NHRA 6390 STK
M/S 85 Mustang
Old 03-21-2022, 11:24 PM   #9
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
When the fuel depot in Pasco still carried VP, not long ago, they did this on a few cans that I had.
Dave Noll, EF/S ,?/SA 6526
