Liked 16 Times in 2 Posts
We're running a '69 Chevelle with "stock" engine/trans placement. It's a powerglide. I originally tried a TCI aluminum trans shield, but there was no way it was going to fit. It was hard into the tunnel and the trans still needed to go up about an inch or so. I've been running a Stroud blanket, but I'm constantly fighting to keep the ends of attaching straps from hanging down... as in multiple zip ties! Is there a good fitting aluminum shield for a glide that will fit the stock tunnel? Thanks!
Liked 431 Times in 224 Posts
This is probably not all that helpful, but I'd highly recommend an aftermarket transmission case that removes the need for an additional shield.
It'll fit, and in my opinion greatly simplifies the transmission installation/removal process in addition to being more durable and probably safer.
S/ST 51 S/C 53 |
Liked 1,945 Times in 586 Posts
If it’s a race car cut the tunnel and raise the tunnel wher needed.
Mike Pearson 2485 SS |
Liked 237 Times in 126 Posts
Ditto. I took a torch and a BFH to my 68 Mustang to get a C4 with a shield to fit.
#5 | |
Liked 520 Times in 176 Posts
In my 1969 Chevy Nova I used a shield from TSR, and I had to "dimple" the floor where the fire wall and floor seem join's together. The shield that Chris and Craig sent me fit the trans case pretty close, but there was two pronounced corners on the top of the shield, just behind the bellhousing transition. That's where I had to "dimple" the floor. Other then that the shield fit pretty good. Maybe give TSR a shout and see if they can help you out. Also loosen the hardware and try pushing the shield to get it as close to the trans case as you can & retighten all the hardware. Check the fit. Respectfully, Henry Kunz 1534 H/SA |
#6 | |
Banned
Liked 179 Times in 89 Posts
I cam across this, thought you might find it interesting.
How to install a JW Ultra-Bell Housing without ruining it and make it look factory |
