Old 01-20-2022, 02:04 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Moroso 20812 oil pan.
Ignore the title the number is wrong. Is anybody using pan 20182? If you look on Moroso’s website. It shows a one piece stamped pan. But if you look on any of the mail order pages. It shows a pan with the bottom of the sump welded on. It’s on the NHRA approved list. But I’m told your not supposed to have welds on the outside of the pan. Just want to make sure it is a one piece stamped pan. Before I buy one. Then If you look on Jegs page it shows the welded sump pan. But if you buy it from them through Amazon it’s a one piece pan in the picture. Thanks in advance for any help I can get here to confirm which one it is. I’ve sent emails to Moroso and all the mail order companies. Nobody will reply.
Old 01-20-2022, 02:06 PM   #2
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Default Re: Moroso 20812 oil pan.
Old 01-20-2022, 02:25 PM   #3
Rob Petrie E395
Originally Posted by Tim H View Post
20182 rather than 20812 ?
Correct 20182 is the one. I switched numbers in the title. And didn’t realize it until I posted the thread. And it won’t let me edit it.
Old 01-20-2022, 03:11 PM   #4
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Legal pan 1 piece not welded
Old 01-20-2022, 03:54 PM   #5
SSDiv6
Liked 1,603 Times in 583 Posts
There are several other oil pans in the NHRA Accepted parts list, for other applications, that are welded and not stamped.
As an example, the approved Chevy II Milodon Oil Pan, P/N 31060 is welded.
Old 01-20-2022, 06:26 PM   #6
Rob Petrie E395
I guess somebody saw this at one of the companies and just emailed me. It’s a 1 piece stamped pan. I’m just trying to be careful and not cause myself problems and headaches later. By buying or doing stuff thats not right.
Thanks guys
Old 01-20-2022, 10:03 PM   #7
B Parker
Liked 2,343 Times in 465 Posts
Call Moroso and ask for Scott Hall. I'm sure he will be able to help you out. They will also do custom work on the inside of the pan if want. BP
Old 01-21-2022, 11:49 AM   #8
garyc
Liked 51 Times in 30 Posts
call moroso directly, they answer every time, scott hall 203-453-6571 he lives down the road from me
garyc is offline   Reply With Quote
