Old 01-13-2022, 11:59 AM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Oil pan question
OIL PAN
OEM or NHRA-accepted aftermarket replacement oil pan permitted. Windage trays and/or baffles permitted. Modifications of any kind prohibited. Crossmember may be altered for oil pan removal. If altered, all material and strength must be replaced by boxing or installing removable or permanent material.
The rule is kind of clear as mud. “Windage tray and baffles permitted. Modifications of any kind prohibited”. So are we allowed to add baffles, windage tray and trap doors or not? I’ve read through literally every single oil pan post on this website. And I’m still not sure. The pan I want to use (Moroso 20182) is NHRA Accepted and has a baffle in it. But there is no trap door in the hole of the baffle. I was thinking about adding one. Also I see in several posts. Where people have sent their accepted or OEM pan to Steph’s to be worked on. Assuming we can do stuff inside the pan. Does anybody know who I should talk to there? Or do you have a better suggestion for a SBC with one piece rear main?
Thanks
Old 01-13-2022, 05:23 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Oil pan question
Must look stock on the outside , all the baffles and such need to be inside .
Old 01-13-2022, 05:27 PM   #3
SSDiv6
Liked 1,607 Times in 584 Posts
Originally Posted by Rob Petrie E395 View Post
OIL PAN
Thanks
You can add baffles and trap doors inside. It has to look OEM from the outside.
Stef's offer the modification service for Stock Eliminator oil pans.
SSDiv6 is online now   Reply With Quote
Old 01-13-2022, 08:32 PM   #4
Rob Petrie E395
Ok thanks guys. I sent Steph’s a email.
