Old 12-11-2021, 03:43 PM   #4
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
Default Re: Wilwood Brake Corvette Front
Walt does the threaded hole for #6 go all the way through the spindle? If it does I think I would go down to a 5/8" bolt with a nut on the backside of the spindle
If the thread does not go all the way thru you may need a 3/4" "bottoming tap" to get enough threads in that short a distance. Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
