Liked 1,887 Times in 579 Posts
Sounds to me like a super C would be ideal for you
many of those have diesel engines. Some under 28 foot and no special license required. and heavy enough to tow just about anything. Or do as I did and just build your own lol
Liked 3,263 Times in 990 Posts
I thought Joe Costello had done a “Inside the Pits” segment that included your rig….got a link? I couldn’t find it.
Regarding gas mileage with a Ford V10, although it is not a motorhome, I have a 99 F350 Dually 2wd with a V10, 5 speed, and 3.73 gears. Last year, I did a 4000 mile move from the West coast of Canada, to the East coast. My truck was loaded, the 24 foot enclosed trailer was packed full of car, tools, parts, furniture etc, total combined weight was right around 20,000 pounds on a truck scale. I kept tracked of my gas mileage for the entire trip, the worst mileage was 6.97 MPG going thru the Rocky Mountains in British Columbia and Alberta, best was 8.59 MPG on the flat land.I towed in 4th gear (no overdrive), at 62-63 MPH, taching about 2700 RPM. Empty, the truck has gotten 15 MPG on the freeway in 5th gear. I really like the V 10, very smooth and quiet. My truck has the early version, which has 2 valves per cylinder, later in the mid 2000s, Ford went to a more powerful 3 valve version in the F series trucks, but my understanding is that the Econoline and motorhome platforms were all the 2 valve model.
NHRA 6390 STK M/S 85 Mustang Last edited by Rory McNeil; 12-02-2021 at 04:55 PM. |
Liked 557 Times in 217 Posts
I have a 25’ Class C E-450 V10
Tow a 26’ enclosed with dragster and lots of spare parts Have used it since 2014 with no problems I re-enforced the hitch and rear frame. Added air bags, good shocks and steering stabilizer up front. Have a real good hitch with sway control. It’s certainly not the best rig possible but has worked fine I don’t have a lot of room at home for anything bigger and used my Duramax pickup with a Lance camper for over 10 years. My little motorhome is way more comfortable If I had it to do over I’d have bought the next larger length MH. About 2 feet longer overall length and wheelbase. The longer wheelbase would handle better I believe. Gas mileage is around 7-8 at best with or without towing. 4:56 gears and 25-2600rpm+ at 65/70+ 5 speed AOD trans.
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 12-02-2021 at 05:06 PM. |
They did and I never saw it either I know there was a problem with my stereo playing Van Halen they said they wouldn’t be able to use that due to copyright so I’m not sure what happened. And I call my motorhome a redneck renagade. Maybe problem with that too. I would post a pic of it but not sure how I don’t have a photo account
Liked 24 Times in 17 Posts
My advice go with a Super C on a Chevrolet Kodiak 5500 Chassis.
I had a E450 32ft with the V10. It pulled my 24ft @ 8000lbs ok. I braced the rear frame, Coil over shocks, Air Bags, sway bar, load distribution hitch etc. Still just pulled OK. Gas mileage was 6MPG no matter what and it only had a 38 gallon fuel tank and only a 35 gallon water tank. Problem was stopping it. If you had to hit the brakes hard it would slide the front tires. After about 6-8 hrs I would be wore out. Sold it and bought a 2006 Gulfstream Super C 36ft with the Duramax on a C5500 Chassis. It had airbags on it, I added front and rear track bars and Bilstein Shocks. I also added a PPE programmer and did the EGR delete. I pull a 28FT ATC with car and golf cart with total weight of 10,500lbs. Pulls it with no problem, Stops well, has a 100 gallon water tank, and a 80 gallon fuel tank. Pulling the trailer it gets about 10MPG. Flat towing my Jeep Rubicon it will get close to 12MPG. Can drive one handed and go all day if needed. Here's one for sale https://www.ebay.com/itm/11512229660...AAAOSwo8php~gO Last edited by NSSGTO; 12-03-2021 at 12:33 PM. |
Liked 239 Times in 90 Posts
I would advise to stay away from the 8.1 chevy. Big block chevys do not like rpms and most all gas rv's have 5.38+ rear gears. The ford v10 is a great engine(and I am a chevy guy lol)Just get one thats newer than 07(more hp and better longevity). Super C's are overpriced in my opinion. You can get a diesel pusher with a cummins and allison for about the same price. One with a 5.9 cummins would be plenty, just make sure it's an 06 up. The earlier ones had pump problems
Liked 19 Times in 9 Posts
What ever you decide keep a few things in mind.
Get the biggest and best braking system available. Air brakes with a Jacob break are best. Sometimes drums are as good as disks. Get the best chassis available. Surprisingly, some don't require added sway bars, special shocks and stabilizers. Do check the posted Gross Vehicle Weight (GVW). Stay three or four thousand pounds from that number. I try to go 8,000 #s. Believe me, this is hard to do. Get the largest HD tires that fit. They are done in about 6 or 7 years, no matter the miles. All tires are DOT dated. Finally, I kind of like the bigger motors. They are generally cheaper to maintain. Motor homes built after 2008 are not as well built. It was 2008 when the really good companies were forced into bankruptcy (economic issues). Construction quality changed after that. |
Liked 317 Times in 103 Posts
Really appreciate the feedback, would like to hear more from all of you out there. I see lots of nice MH in the 32'-38' range with diesels but only have 5,000 capacity, along with being beyond my vision with the trailer.
Ron Ortiz 2102 STK |
