Old 11-25-2021, 08:18 AM   #1
SGSST109E
Liked 126 Times in 61 Posts
Default Re: Leakdown Testers
HAd a Moroso 89600 for 50 years it finally started to read high. Bought a OTC 5609 two guage unit. Its accurate and repeatable.
SGSST109E is offline   Reply With Quote
Old 11-25-2021, 10:51 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Only $74 on Amazon right now (with Prime membership anyway) and looks to be made in USA unless I’m missing something.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-25-2021, 11:36 AM   #3
340Cuda
Liked 805 Times in 341 Posts
I have the OTC tester also and it seems to work well.
Old 11-26-2021, 10:37 AM   #4
mschafer
Liked 13 Times in 9 Posts
Thumbs up Re: Leakdown Testers
I have a OTC also ,works well and would recommend it.
mschafer is offline   Reply With Quote
Old 11-28-2021, 06:12 PM   #5
Dave Bergfeldt
Liked 8 Times in 6 Posts
Do Not .... I repeat Do Not get the Harbor Freight unit ... Difficult to use ... inaccurate numbers!!!!
Dave Bergfeldt
106 SST/SG
Dave Bergfeldt is offline   Reply With Quote
Old 11-29-2021, 09:13 AM   #6
sst5167
sst5167's Avatar
Liked 17 Times in 9 Posts
I bought mine off a Cornwell truck quite a few years ago. I use mine after every race on both car as part of my routine maintenance, and it's been perfect. I would buy another one if I needed too.
sst5167 is offline   Reply With Quote
Old 12-12-2021, 04:27 PM   #7
reknapp52
reknapp52's Avatar
Liked 7 Times in 5 Posts
Turns out my brother has a Matco tester that I will be using. Do I need to warm the motor before running the test? It's been parked in my garage for about 3 weeks without being started. Also, what numbers are acceptable? My motor is 447 C.I. with 14.3 compression.
reknapp52 is offline   Reply With Quote
Old 01-31-2022, 02:49 PM   #8
garyc
Liked 51 Times in 30 Posts
whats normal leak down on a new motor? does it matter what ring package?
thanks mike
garyc is offline   Reply With Quote
Old 01-31-2022, 04:50 PM   #9
garyc
most times leak down was used to find a dead cylinder
Old 01-31-2022, 06:29 PM   #10
FED 387
Liked 333 Times in 180 Posts
definitely less than 10% and if you have gapless end rings less than 5%---if its a tight motor AND NEW never started you are going to see about 3-4 to maybe 5 - 6 %---watch for variations between the cylinder readings especially those cylinders that are next to each other-- not small ones like a few percent but big differences like 10-30%--FED 387
